Hello - I need your help
I went to start my twin 1973 318 engines and neither one of them would fire
Pulled a spark plug held it to ground cranked engine - no spark
Pulled coil wire held it to ground cranked engine - no spark
There is 13.50 v at the + side of the coil. Using a screwdriver and Ign Sw on I found sparks at the points.
Put a jumper wire on the - or points side of the coil - held coil wire to grd and with the other end grounded it off and on- no spark.
The + side of the Coil is connected the new Ballast Resistor. The - side is connected the points.
All of this tells me that the Coil is no good. So I went and bought a new one - still no spark
The only thing I have not done is to replace the Points and Condenser. They were new last season.
I have used 3 different Coil wires They are not new.
Any help will be appreciated
