"Does anyone know if it is pos
"Does anyone know if it is possible for both the primary windings, and the secondary windings to read as an open in my coil ?? I have the EST ignition.
12 volts at coil, and out to ignition module
both coils show open to ground, and no continuity through the coils.
Seloc says I should have 7500-9000 ohms through secondary windings, and .035-.045 ohms through primary.
I am using a digital multi-meter set on 2 ohms ( only available setting ) I am assuming the decimal will move places with higher resistance. Would I have have better luck with an analog meter, or do these readings seem realistic, and the coil is junk ?"
