pugetsounder
Advanced Contributor
"OK since I decided to try out
"OK since I decided to try out the Hot-Spark electronic ignitor I decided to research a new coil as well. Talk about confusing. I guess I need to figure out what I have first. I have a later model AQ140A not sure what year since it didn't come with the boat. But how do I decifer ohms resistance, is it primary or secondary? Then how do I figure out if my coil has internal or external resistor? All I know is the Ignitor set up needs at least 3.2 ohms but I would like at least 40,000 volts output. Then there is the cooling fluid inside the coil. Can anybody suggest a brand name and number aftemarket Ignition coil for the electronic ignitor set up? I'm pulling my hair out at all the choices but I just want the right one. Thanks a bunch."
