Idles fast 150GT
cbeam2
I've got a 1990 Johnson 15
I've got a 1990 Johnson 150GT. I started it for the first time in 5 months and it won't idle down. Before you could tap the gas or it would idle down by itself.
What can I check for?
Chuck
"ck linkages,making sure they
"ck linkages,making sure they r returning to idle position,...make sure carb butterflies are closing...then,i would look into the 'quick-start' feature,for remaing on,after 105 degrees."
"I just solved the same proble
"I just solved the same problem on my 1989 200XP.
My problem turned out to be the "Timing Advance Linkage". Discovered that the lubrication, on the internal parts, had become so deteriorated that it had the consistency of molasses. This sticking was causing the timer base to NOT return to its idle setting. After cleaning the linkage assembly, and performing a "Link-n-Sync", the idle returned to its original settings.
You might look at your timer base and see if its returning to its idle stop. If its not, check your Timing advance linkage for the problem I described. Good Luck!!"
