"I have a 1996 5.0 Fuel inject
"I have a 1996 5.0 Fuel injected engine that is surging when idling. I have checked for vacum leaks tested the TPS voltage at idle, cleaned the throtle body and the IAC. It seems to help if i advance the timing a little. Fuel pressure is good at 40 psi. I also seem to have have lost some power at W.O.T. I can only get about 4000 rpm out of it with a 19 pitch prop. The boat is a 19' Four Winns cuddy. The motor is rated for 4400-4800 max. It came with a 21 and a 19 pitch prop. Seems like I should have more rpm lightly loaded with the small prop. I could not plane out with 5 people on board unless I moved folks toward the front."
