neversummer
1989 5.0 V8 owner here with a
1989 5.0 V8 owner here with a question about idle. I had the dealer do a tune up this spring and install a new thermostat (apparently the thermostat had been removed by the previous owner) and ever since it has been idling a little weak (engine "pulses" slightly and sounds like it is not getting enough gas). After starting I need to rev it a bit to keep from stalling. Other than that it runs perfectly...could this be water in gas/Ethanol problem? Should I try to adjust the idle screw? Thanks very much.
