Idle Problem 2008 Mercury 50 Hp 2 Stroke
gw09
"Please help!
I have a 2008 M
"Please help!
I have a 2008 Mercury 50 Hp 2 stroke. Starts good. Runs good. But, sometimes when it has been idling for a while it will die. Idle speed at idle or in gear is right on, but, at times it will like take a sneeze and just die. Help me, please. I get really dispondent with it especially when I am going to load (pontoon) back on the trailer (and you really need the motor running) and it dies.
Help!!"
Running fresh gas?
Try some
Running fresh gas?
Try some new sparkplugs and get yourself a can of Merc's "Powertune" - follow the directions on the can and clean the "cooties" out of the motor.
If that doesn't correct it you may have to do some carb cleaning...
"Mr. Lamb. Thanks for the rep
"Mr. Lamb. Thanks for the reply. I have good gas.
I put new sparkplugs in. Guess I will try the powertune stuff. It drives me nuts. It can run good on idle (in gear and out) and then boom, sneeze (if you know what I mean) and die. Since it has oil injection you wouldn't think that it is loading up on oil."
"The sneeze could be because i
"The sneeze could be because it's running a little to lean - but I would try the decarb with powertune first.
At worst, you will have a clean powerhead that requires a small adjustment."
