Swenson514
i have a 1994 Johnson 90hp v4 and the person that had it before me had the oil injection go out on them and that's all i know. now i mix the gas and all the oil injection stuff is either plugged of or disconnected. when you start the boat right away you have to let it idle at about 2 grand for like five minutes it seems or if you go to take off the motor will stall out on you. if you try to troll or drive slow the motor will also spit and die on you. when you put the throttle all the way open it studders a little then once up to speed runs like brand new. when you slow it down again to idle or troll speed it still runs good for about five minutes and then dies again. now when you go to start it you have to rev it up and let it idle high again for about five minutes before you can put it in gear again. i have rebuilt the carbs, put new plugs and wires, and i have also put new head gaskets in because i thought maybe water was leaking in or something causing it to stall out. any thoughts would be desperately appreciated. thanks
