Doug Schepp
Took the boat out to the lake today to fire up the motor for the first time this year. When the motor fired up I had to be quick to get on the throttle or else it would die. Figuring it was just from being cold I held the throttle about halfway for about 5 minutes. Once it was warm I tried to throttle down and it just died. The motor starts with a few pulls, but it just seems like its choking out. I've never worked on a boat motor before so I'm not even sure where to start looking
- Plugs and wires are new
- there is a steady stream of water being release (peeing)
- there is water spraying out the back (two little holes)
- Fuel is 87 octane (no ethanol) with a 50:1 oil mix.
- Sounds good at higher rev (no missing from what I can tell).
- Shifts in and out of gear fine, but had to do it at a higher rev.
There was blue-ish white smoke coming out of the two small holes (same ones that were spurting water)....not sure if that is helpful in figuring out whats wrong, but I figured I'd throw that out there.
Any suggestions would be greatly appreciated.
