"All HELP NEEDED AND APPRECIAT
"All HELP NEEDED AND APPRECIATED!!!!
1975 25hp Johnson 25R75B
New seals & o rings in lower unit.
New water pump. (pumping)
New carb. kit. (including gaskets).(clean)
New points and condencers. (@ 20)
New plugs. (4's) Champions (@ 30)
All is great from a cold start idles great nice and smooth.
Excerlatetion smooth/ mid smooth/ top smooth.
As motor WARMS / 1 to 2 hundred yard run.
Top end stays fairly smooth and crisp*(note 1)
Mid is hampered a small bit (not real bad).
Idle will sputter, or sneeze, or spit, (jerking)then dies (as if too lean).
Mixture set @ 1 and 5/8 OUT. Trying many different settings.
Warmer it gets, the worse it gets, but motor does NOT get hot.
Confusing several good mechanics.. (me also).
Clean fuel 50 to 1 ratio. (No water).
Clean fuel lines. (No air leaks). (tight fittings).
All orfices in carb clear.
Water passages clear.
Thermostat removed (to eliminate suspicions).
Compression 125 (both cylinders).
Good spark at plugs. (Checking while not running) NO timing marks.
All is set at specs since parts are new.
The note* was at top end (wot) it is shearing prop shear pins...????? and I'm not hitting any thing at prop.
Really 2 issues that are Really confusing.
I'm wondering can it be vapor lock/ or maybe timing or.....?????????
Will greatly apreciate all imputs and suggestions.
Please help put (little ole me) on my fishing hole with no worries.
THANKS!!!
DAVE."
THANKS!!!
DAVE."
