thecopperdoc
Just put a 4108 into a 30 foot
Just put a 4108 into a 30 foot steel yacht that im building. The engine is a recon and is in good order. The original dash and loom came with the engine but was is in poor condition and wasnt connected or tested.I need A STRAIGHT FORWARD DIAGRAM to tell me what connects to what???
list of whats there
oil pressure gauge with correct single wire sender
oil pressure light
sounder
red light
water temp gauge and sender
volt gauge
alternator (believe original lucas)with plastic rear cover.one connection at top rear and three together at bottom (middle one is bigger)
original starter(two nut connections on solenoid and small spade connection)one small nut connection at rear bottom of starter body)
original perkins starter key (4 connections)
please email me if you can assist ...thanks Rob
list of whats there
oil pressure light
sounder
red light
volt gauge
