Philfry159
I'm chasing a fuel gremlin in my Johnson 40 HP VRO - Model J40ELCDE outboard motor. I prime the engine and it starts immediately. I put it in drive in low speed and it'll go for a little bit before stalling. When I put it in full speed it lacks power and will occasionally rev and give more power. If I continue to squeeze the primer bulb while the engine is running it has no issues. I'm thinking its a problem with the fuel pump/diaphragm, however, when I removed it and opened it up I didn't see any visual signs of issues with it. I'm going to try and replace the entire pump.
So far I've done the following which has not corrected the issue.
- Bypassed the fuel filter to check if its a issue with the filter being clogged.
- Replaced the fuel with new fuel to make sure its not a issue with the fuel.
- Removed the quick connects to make sure its not a issue with loss through the quick connects.
If replacing the fuel pump/diaphragm doesn't work I'm going to replace all the fuel lines. Any other thoughts or suggestions on what this might be.
