oil driver
I am trying to identify a lower unit as to rotation. When I pull up the shift shaft the prop shaft and the drive shaft both turn clockwise. Is this a standard rotation lower?
Model # ??
94 ocean pro 225. I need to do the seals. I have been trying to pull the carrier. I have been spraying it with a mix of wd40,pb blaster, and marvel mystery oil. My puller has the same thread as my prop shaft, so I tried it and lost half the thread on my puller. I tried heat but I'm not getting even heat, so I'm going to get a shrink wrap gun or maybe just use my seal puller and give up on the carrier. Then what I want to know won't matter till I find out it's a left hand rotational lower and I have to buy a prop.
I am looking from behind the unit
