Hi, I'm looking for a little guidance in correctly identifying the type of bearing system I have (gimble, single pds or double pds)
I've searched quite a bit but have found conflicting info, or basically I'm just confused.
Here are the serial #'s that are still legible (barely).
Transom assembly
Dps (290) 4111521532
Engine which is a Ford 351
5.8fsi phurce
4110120061
Most of the drive unit # is faded away and is illegible.
Any and all help is greatly appreciated.
Just a side note, when I changed the bellows when I bought the boat a couple years ago the u-joint assembly was covered in surface rust leading men to believe that it had water intrusion at some point.
seems how the u-joint is rusty I would imagine my bearings also need attention.
correct?
Thanks again for your help, this site has been a great resource.
Transom assembly
5.8fsi phurce
4110120061
correct?
