Keithm18
Hi All.
I drained the gear lube on my 81 Johnson v4 90 hp and just under a quarter of a cup of water was the first thing to come out. Using my home made pressure tester the gear case did fine with around 10psi for just under ten minutes.
i have no way to vacuum test and i beleve from reading other posts that a warm gear case will pull water in when cooling in the water.
There's a chance it's the seals on the filling and drain plugs for the gear case, but as it's now winter over here and as the seals are now possibly 32 years old, i thought i would look into replacing them, which was also suggested routine maintenance previously on this site.
There were very few fine iron filings on the magnetic drain plug, but there were no chunks of steel or heavy meal filings in the drained gear case oil. The gear case also goes into and out of gear very smoothly (smoother than my mates 90's mercs or mariners) so i am pretty sure the internals are all good.
I'm worried about taking the whole gear case apart to replace these seals due to the complexity and precision of the gear case that i am looking at ways of replacing the sals without dismantling the entire gear case.
from what i an see there are three main seals. Two where the prop shaft exits at the front of the gear case. Two where the drive shaft enters the gear cas, under the water pump and 1 where the gear shaft enters the gear case.
I found a method by a guy who did two yamaha gear cases, by drilling and pulling the seals with screws and then pushing the new ones in using a type of socket on youtube. In his method he only removed the seals and none of the circlipe and other retaining bolts.
Can anyone give me some guidance on the easiest and simpleest way to do this kind of work with minimal specialized tools and complexity?
ps i did put new lube in while i'm deciding what to do so it's not standing empty and wet.
Thanks as usual.
Thanks as usual.
