navchapdoc
"Here are the facts..1994 90HP
"Here are the facts..1994 90HP Merc. Top and mid cylinder at 115 and 105. Bottom hole at 80. I took the air box one day and found a small puddle of gas/oil in the bottom carb throat, last time I took it out at 5000rpm the overheat alarm went off until I took it down to 4000 or below. Runs pretty well over all. Seems to smoke a bit more than I think it should when being flushed out in my yard. Here is the question...Could this low clyinder be a bad head gasket?? The plugs were changed just before I bought it so I dont know what they looked like. The carbs are being rebuilt completly this week. My Mech said the reeds looked good. The cylinder head where it meets the block looks good, no sign of corrosion. Could this be something other than a piston and ring issue??? I was thinking about the gasket cause of the overheat thing at 5000. The pump and impeller are new, so is the sending unit and poppet valve so I know water is flowing
Thanks alot!
John"
Thanks alot!
John"
