Gjkelley31
Hi guys, I have a 1974 40 HP Johnson. I fully rebuilt and cleaned the carb before this which fixed the needle valve that wasn't closing causing causing to spit out the carb. Anyways, afterward it still hasn't been starting or if I get it to sputter, it doesn't stay running/idling and always only if the choke is on. I opened the carb back up today and noticed that the new float isn't really lifting all that much when you flip it back and forth. I'm not sure if it's opening the right amount or not. the bowl was filled with gas when I opened it up. Here are some pics to show what I'm talking about. Looks like the tab on the float that keeps it from opening too much is really long. Let me know what you think. I really want to get out on the water atleast once this summer.
https://i.imgur.com/KgYiyPM.jpg (Float on top carb orientation -needle closed position)
https://i.imgur.com/sL9Avtj.jpg (tab looks big)
https://i.imgur.com/Z3IskeD.jpg (float on bottom carb orientation [needle "open" position] where float should hang. Angle looks small, needle doesn't seem to lift)
