J
Joe Dawson
Guest
" Engine is a '78 Evinrude
" Engine is a '78 Evinrude 85hp. I am trying to install a choke solenoid that was missing when I got the boat. The choke is actvated by pushing in the ignition key as you turn. I have the new solenoid mounted securely and grounded. My question is where to connect the purple and white hot lead. I have been told by several to connect it to the terminal board where I would find another purple and white wire. I do not have any other purple and white wire on the terminal board. Additionally I have tested the circuts on the terminal board and found hot circuts, and circuts that get power with the key in the on position. No circut gets power when the ignition key is pushed in. I have also consulted my Clymer manual for a wiring diagram for "'78-'79 V4 Engines" that shows the solenoid wired to a component that is not labeled. Please pardon my ignorance, I am fairly mechanical but new to outboards. The components are depicted as circular with numerous wiring connections and one for each side of the engine. The only other thing I will mention is that some have told me that the 78 and 79 models are somewhat unique and different from other OMC models. Thanks in advance for any help. Joe "
