I have spent the entire summer fighting this engine. Here is entire story. Motor ran awesome 5 years ago. Motor was pulled and kept in dry storage while boat got floors, transom, etc. put motor on. Compression 120-125 all cylinders. 1987 Mercury 115 tower of power. Reinstall. Fire it up. Runs a little sluggish on the hose. Probably needs a carb job. Do carbs, no spark. Troubleshoot no spark to trigger. Stator was original so replace them both. Now intermitten spark, some cylinders yes some no. Put new switching g boxes on it. Now pump up ball. Hard start. Hits quick and disengages starter. Has new correct anti fouling plugs. Once it finally starts idle kinda rough. Moving the high speed lever (shifter does not allow for throttling when not in gear). It will slowly idle up. I can put it in gear and rev it, it’s slow but will get there. Put in the water and it will barely move, I would guess less than 2000 rpm. Can put my hand over each carb to choke out and can pull fuel. Try to throttle up and it sounds like an old Quadra jet and bogs and dies. Local shops are at least 6-8 weeks out. Talked to a guy today. My thought was timing. He said it should run better than it is even if it’s off from the trigger replacement. He asked about mud dobbers and there were a few under the cowling. He thinks maybe a nest in the exhaust. I have never messed with the fuel pump. I put a new water pump in it but didn’t look up inside for nests. Someone please give me some good avenues to chase. Also running of a 6 gallon tank with fresh fuel. New primer bulb and all new fuel line. Removed the quick disconnect from the motor and goes straight from tank to pump with a new inline clear filter. Thanks for your replies.
