I need a little help please
spicerak
hi i have a 150 hp evinrude xp
hi i have a 150 hp evinrude xp.the power trim works fine from the switch in the front but the switch in the back dosent work.i replaced it with a switch to one from west marine its kinda was the same a little more prongs but i still couldnt get it to work.should i cut those wires and touch them together they are green blue and pink.i looked at the relay and it looks good not sure what to do please let me know thanks guys
"Unit functions via the front
"Unit functions via the front switch means that nothing is wrong with the relays.
You've got three wires, red, blue, green.
Red to Green = Up
Red to Blue = Down
Wire the switch accordingly."
do i have to have the right sw
do i have to have the right switch or can i use the ones the sell at west marine.the one i had only had three prongs the one i bought had like six prongs.i tried like every other way to stick the wires on and still didnt work is there any way to cut wires at switch and touch them one at at time and see if it works thanks for your help
so your saying it will not wor
so your saying it will not work at all with the switch i bought why wouldnt get i me some kinda power out to do something.is there any way to check it without the switch thanks for your help
"i dont know,what sw u bought,
"i dont know,what sw u bought,...sounds like one,to run 2 diff things,..like a dash sw on newer boats,....to ck the wiring,u r trying to hook to,...strip back a half inch,..and conn red to blue,..red to green..it should operate,..if not,..get the correct sw,..and ck your wires for the trouble area,..poss a bad connection in one wire......
see if u have 12V on red...this is first step,..if so,..start checking the others,specifically,...looking for butt connections,that are corroded,broken etc...
your system,..is not the area of trbl as joe says...it works from other sw,...your wiring at back,....is the prob,unless it wks as i say above...ck that red wire.."
"The toggle switch with 3 pron
"The toggle switch with 3 prongs is called a Single Pole Double Throw switch, abbreviated to simply SPDT.
The toggle switch with 6 prongs is called a Double Pole Double Throw switch, abbreviated to simply DPDT. This switch is simply 2 of the 3 prong switches sitting side by side.
Ignore the 3 prongs on one side and connect the wires as shown below (The zeros represent the prongs).
Nothing here -> O....O <- Blue wire
Nothing here -> O....O <- Red wire
Nothing here -> O....O <- Green wire
When time permits, visit my eBay store at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
awesome guys it was the red wi
awesome guys it was the red wire broke in a connection thanks.hey one other question i just did a de carb all compression around 90 for a 150 evinrudewhen i use it for a while the plugs on one side seem to get like dry maybe carbon build not sure is that normal
