paczowski123
i had originally posted something about my lower unit leaking from a weep hole just behind the water inlet on the front of the motor. Well i loosened the lower unit drain plug and nothing but translucent white water came out for many seconds i did not even see anything as thinck as oil flow out
What should i look into replacing in this motor? i inherited this boat with no knowledge of what service has been done the motor is a 90 hp evinrude spl. what seals should i start with first i.e. water pump, shift shaft, or any others?
