Hyrdraulic steering pressure
ghirsch
The pressure gauge on my hydra
The pressure gauge on my hydraulic steering gauge reads 175psi. Operators manual says pressure should be 35-45psi. Should I bleed the system to suggested range? Steering handles fine.
"I would first check the accur
"I would first check the accuracy of the gauge. A simple check with a tire gauge will verify the pressure. Yes, you should reduce the pressure to the recommended amount."
"Gordon
If it was really 175
"Gordon
If it was really 175 lbs it would have blown up by now. The gauge is constricted and reading false pressure. Check the port where the sending unit is, it is half closed with junk I bet."
