I just bought a used Hydrohoist. It’s an Ultra lift, 5000 lb capacity so it’s fairly late model.
I need to adjust the width for the berth I’ll be using and the tubes that slide inside one another don’t slide easily. There not bad, ie, no corrosion, but they are metal on metal that’s been together for awhile.
I need to widen the lift 6”. 3” per side to keep the floats centered. I beet on the ends of the female tube and they move but not much and not easily. I don’t want to mess up the ends of the tubes.
Has anyone ever done this? What did you use to push lift sections wider?
Any tips or tricks would be appreciated.
