Hp fuel pump removal instructions
surfnfisher
Hey all, got a new used 2005 225 with 50 hours which is cool. Replaced my 2004 225 which was a snap. Now have a no start. Removed the bleeder from the hp pump filter and no fuel coming out key on or while cranking.
I believe that means hp fuel pump is not working. I hear a small click when key on from back of the motor.
Does anyone have the removal steps for the fuel pump?
I had removed the vst on old motor a few times over the years to fix the corrosion hole behind it. Just want to make sure I have a clue on what to do and parts to order before I replace.
Any input appreciated.
Just a thought. I have a 2002 225. I have had mine apart . Could be the high pressure fuel filter, or the high pressure fuel strainer.
I have taken mine out as one unit. I’m not sure if your is the same being a 2005.
I hope this helps
