doug_keister
"is there any tests that can b
"is there any tests that can be done to determine problems with Spark or issues with intermitant spark? I don't want to buy a new Stator to find out something else is the cause of the problem?
1995 Johnson 90hp j90tleor
Engine has SLOW feature, was running fine after shop repaired timing and replaced 1 coil. now will not start properly. did get into weeds and slowed water flow got engine hot enough to trigger alarm but after would not run full throttle had to idle back to shore to get on trailer? now has hard time starting."
