Hi,
The Johnson 110 I've been monkeying around with finally made it into the water. It's pushing a 17 foot aluminum boat (hardly a load)..
Compression by my gauge is 95 a cylinder +/- like 1 psi, but I don't really think my gauge is right and suspect it's probably a little higher.
Starts right up and runs OK, will rev up to whatever with the warm up lever, however upon putting it in the water it was like I had 30 HP. Runs fine in gear up to 2000 RPM then if you push the throttle any further either it stalls or just doesn't do anything. Primer bulb, primer solenoid, playing around by trimming the engine up doesn't do anything - might get 2200 RPM or something. Can't even get it to jump up for an instance - would not call it a bog rather it's like there is no response to the throttle.
Carbs just rebuilt. New plugs.
What I noticed upon setting the idle was the screw was practically maxed out. Also seems like there is barely any travel to the trigger and that at full throttle it's at like the center of the entire range you could set it to. The adjustment on the trigger (by the threads on the linkage) is very far in the direction of retarding the timing.
Carbs do open fully upon contact with the throttle stop, however my suspicion is someone mucked with the timing at some point and it's somehow waaay off.
Since I couldn't even get this engine to 5000 RPM if I wanted to, how do I verify that the WOT timing setting is sane? Do I seem on the right track with this or should I go back and verify carbs first?
Thanks!
Jon
Thanks!
Jon
