How to Remove Lower Unit 1985 Johnson Model # J25TECOS
Splendid
1985 Johnson 25 hp. Model # J25TECOS Gear oil is leaking, no water in oil, need to change the seals.
I am trying to remove the lower unit and all the bolts are loose and it appears the shift shaft needs to be released. What is the best way to achieve this?
Any help would be appreciated.
First are you sure its lower unit oil and NOT unburnt fuel from the engine block over flow?There is a small hole on the lower that unburnt fuel mixed with oil exits,Does this oil smell of gas? If it does it is NOT the lower seals and alls OK.
Now if you have to drop it and you have all the bolts out the water intake screens have to be removed,in there 2 nuts have to be loosened then the upper nut will slide up the shaft exposing a small plastic clip that has a split in it,find that split open it and remove that keeper the lower will then drop.and reinstall goes opposite.BUT if that oil is gas smelling just ignor it its common!
Thanks, I am sure that it is the lower seal, it was just leaking a little bit, but now it has a inordinate amount of oil leaking from the exhaust and an orifice (approximately 1/8") hole just above where the seals should be located. It may be a couple of days before I can work on the engine and I will let you know how the progress is coming.
The engine has a fuel problem which is where I started with this project, replaced the diafram in the pump and it appears that the diafram pump is not working properly. The engine will crank, but then it runs out of fuel. If you take the line going to the carburetor off at the pump, you can squeeze the bulb and fuel pours out of the output line from the diafram, but if the engine is cranked with fuel in the bowl, and disconnect the line, then it is not pumping fuel of any quantity. It is almost like the vacuum is not operating the pump. If you squeeze the bulb continuously, the engine will run at a moderate clip and then if engine is opened to planing speed, the boat will travel a short distance and it will shut down to idle. Also, if you continuously squeeze the bulb, it is fairly hard, but if you quit, then it becomes soft. Could not find any fuel leaks between the fuel tank and the carburetor.
Do you have any ideas?
