How to properly repaint a DPS drive
lars11
The drive is quite bad on the
The drive is quite bad on the surface so I want to repaint it. Say that I will start out by brushing it metal clean. Then what?
What primer?
What colour?
What clear coat?
Is there a generic paint system or do I need to use Volvo Penta stuff?
"You do not need to sand the d
"You do not need to sand the drive down to bare metal. Just ensure that the surface is smooth and clean. First prime the leg with a good zinc chromate primer, Petit makes a nice one. Then I would spray the leg with an aerosol outdrive anti-fouling paint (if kept in the water) or a high quality rattle can. The VP paint is much more expensive and does not provide anti-fouling characteristics. Good luck."
"Did both my drives,you need t
"Did both my drives,you need to clean or go to metal and then put zinc cromate primer, I oppted to get OEM paint and decals man my drives are show condition 2 years later a little touch up perfect.
PS my 298 sets on a trailer not in water"
