cannonballkev
I do not have a manual, one i on the way. I am trying to change the shift cable on my 2.3. I have a parts boat that I am messing with first, i pulled the outdrive off, the lower boot (with all the holes in it) un did the cable frome the shift linkage at the motor.
Here is my question, how do you loosen the bolt that is made as part of the cable from the threaded place on the outdrive? The whole cable has to turn to get it loose.
2nd- how do you get cable thru the transom? I got it all the way to the crimped metal casing, I can look at the hole the cable is in and see the start of the metal. On the other end there is a threaded adjuster nut that im asuming is getting hung up.
This is on the parts boat m but i need to know the "trick" before i start on my boat.
