Hi,
I just rebuilt my 04 DF115. Water went with oil and I had to replace crank, piston etc. It started O.K and ran idle very smoothly. So drove to the lake but as I tried to push it to get it to plane, it the motor cut off and won't rev more then 2000 RPM. But run very well if I don't push it over 2000 RPM.
I think that when I had the problem ( low oil pressure), a code was sent automatically to the ENGINE CONTROL MODULE to kinda set the max rev at 2000 RPM. I read in the Suzuki manual that it is what is happening when either the engine overheat or has very low oil pressure, which was my case.
I tried to find a dealer around but nobody within 100 miles, Anybody knows how to take that code out of there without the SUZUKI code reader or whatever it's called ?
Thank's
Thank's
