How to do a compression check
Remove 4 sparkplugs , install tester.----Crank over till gauge stops rising.-----Throttle does NOT need to be open.
Thanks Racerone. What is a good compression number and when should I be concerned not high enough? I've seen different posts about the differences between each cylinder. How far apart can they be?
When we did the compression check we removed all 4 plugs and checked each cylinder. Battery was fully charged. The engine would crank hard and slow. Is this how it's suppose to be or should it crank faster like it does when the plugs are installed?
Normally, it would crank slower with plugs installed. But "lumpier" with all out except the compression tester. Either way, it has to crank it over the compression strokes.
