3nail4life
I can not get the screw out to remove the retainer that holds the fuel pump and filter.
I have had the same problem with that screw. you can try using a long phillips bit with a hand impact driver to loosen it. I ended up removing he fuel ump and screen filter by bending the bracket enough to get them out and then soaking the screw with a penetrant oil over night. the next day I was able to get it broke loose with the impact driver. good luck
