1stboat
"My boat currently has two bat
"My boat currently has two batteries attached to a perko switch with a 1, 2, or both option.
Since I bought my boat I have added an 800 watt amplifier for the sound system as well as added a DC to AC power converter. To accomodate for the added electrical load on the system I am planning on adding a third battery. My plan is to use two of the batteries for the sound system and power converter and the other battery used strickly start the engine. One of the batteries on the boat is bad anyway and need to be replaced so I figured I'd just get two identical batteries while I'm at it.
My question is how to hook the two battery bank together to keep it at 12 volts. Will it take one or two jumper wires? As in do I hook the (+) terminal of one to the (-) of the other battery. Or do I need two wires (+) to (+) and (-) to (-)?
Also, which of the batteries gets the (+) and which one gets the (-) lead coming from the alternator.
I have the amp and power converter connected through a distribution block with 2 gauge wire running from the battery to the distribution block and one 4 gauge wire running to the amp and one running to the power converter respectively. The power wire leading to the amp is wired directly to battery 1 without going through the perko switch. Should I wire the power leading to the amp to the perko switch allowing me to turn the flow of electricity off if need be?
Thanks for any advice you can provide."
