Hi guys, I have a 2006 150 EFI. I had an overheat alarm a few week ends back. There was water coming from the tell tale. The block was so hot that I could not even hold my hand on it for a second. I changed the impeller and the overheat warning alarm does not come on anymore. After I took the boat out of the water yesterday, I took off the cowling, and the block is still very warm, not as hot as it was before I changed the impeller , but hot enough that if I hold my hand on it for more than a few seconds I get burned. Is this normal? I don't know if the block would be cooler if the motor is running, as I had already taken the boat out the water. Before I took it out it has been running for around 2 hours with no overheat alarm. Just wondering how hot the block should be once the motor has been turned off for around 20 minutes. Regards Greg
