Even at 5000rpm - yep!Trick question ?-----But on a 2 stroke running at 5000 RPM there is not much time.----like 10 milliseconds or less.
Fuel, mixed with oxygen, burns at a constant rate and produces pressure as the gasses expand. The optimum mix of fuel to oxygen ratio for petroleum is 14.7 parts oxygen to 1 part fuel and is known as the stocimetric ratio. So this is kinda a fixed variable. Add more fuel/oxygen and the rate of burn will change. The other variable is ignition timing.Lets talk about outboards that in general run around 600RPM at idle to 4-5000RPM at fun speeds. For most of us I would imagine. Starting at the low end, Idle. And I'm targeting this at 2 Stroke owners, as this is where the issues most lay.
I see your point. A lot of input here does not suggest a breath of knowledge. SorryTrick question I guess.-----Or how long does it take for bullet to leave the barrel of a gun ?----How long does it take for a fission bomb to produce it's power ?
2 strokes also have port timing another variable I think.Fuel, mixed with oxygen, burns at a constant rate and produces pressure as the gasses expand. The optimum mix of fuel to oxygen ratio for petroleum is 14.7 parts oxygen to 1 part fuel and is known as the stocimetric ratio. So this is kinda a fixed variable. Add more fuel/oxygen and the rate of burn will change. The other variable is ignition timing.
So. Suck, Squeeze, Bang, Blow is basically it. The difference between 2 stroke and 4 stroke is mechanical. The secret is understanding those secrets. How each mechanical mechanism treats suck, squeeze, bang blow - their tansition from idle to pick up and on to power flow with air, fuel and ignition is quite different.
Every engine is designed on it's BMEP. How far down a pistons power stroke the full burn of fuel produces the maximum push on the piston. Timing is the most variable.
Cheers
