How do you remove a propeller shaft bearing housing
tim_l
"I have a 1983 1.6 liter OMC S
"I have a 1983 1.6 liter OMC Sea drive out board engine, and it is leaking some oil out of the lower unit. I tried to replace the seals but I cannot get the propeller shaft bearing housing off to get to the seals. Please Help"
"have you checked out the diag
"have you checked out the diagrams on -shop.evinrude.com, or boats.net-they may help, otherwise youll have to wait for a response from one of these other guys with more experience in that area. sorry not any help."
"ok........there are 4 screws,
"ok........there are 4 screws,waaay down in there...3/8 or 7/16..then u will need a slide hammer or a puller set."
"How would you use a slide ham
"How would you use a slide hammer to remove it, and when you mentioned a puller set, did you mean a wheel puller?"
yes a wheel puller with 2 thre
yes a wheel puller with 2 threaded rods you have to rig it with nuts tho.put pressure on it then give it a few taps with a hammer crank it again
/tap /crank/tap....did i mention a little lube
"Hey Tim, I just had to pull t
"Hey Tim, I just had to pull the bearing housing earlier today to check out my gears & clutch dog. I just stopped down to my local Autozone, they let you borrow certain tools if you leave a small deposit. I got a timing gear puller, bought a few 12" threaded rods, washers & nuts and it ended up working like a charm! Pulled it right out of there in no time! Now I just have to track down a bigger set of snap ring pliers... the ones that I had were WAY too small to pull the 4" retaining rings out of the gearcase.
Bearing Housing Puller Setup
"perfect!..excellent pix too!!
"perfect!..excellent pix too!! he wont need the snap ring pliers tho,just to re-seal."
I called up auto zone and they
I called up auto zone and they said that they had different types/ sizes of timing gear pullers. Which kind/ size should I get?
"I just got the standard one t
"I just got the standard one that they loan out to people. Just check out the pictures I posted above, and then take a look at the ones that they have to loan out. Shouldn't be too much difference though. Don't forget to buy the threaded rods, washers & nuts too... you will need them as the included bolts are too short for the job."
