"In your first post, you said
"In your first post, you said the manual was not clear on prop removal. If the nut and lock tab have been removed and the prop does not slide easily off of the shaft, then the problem is probably that the prop has become stuck to the shaft due to the onset of corrosion. This is quite common and has happened to me. To remove the prop, you'll have to use a propane torch to heat the prop and melt the rubber around the prop hub. This can be tricky and if you're not careful you can damage your prop shaft seals. What I did is I had a "prop puller" manufactured by a friend who is a welder. Using the heat and prop puller you should be able to remove the prop but unfortunately in most cases, the hub will remain stuck to the shaft. To fix this, use a 4 0r 4.5 inch grinder to cut the hub lengthwise, pry the cut apart and remove the hub, being careful not to damage the prop shaft. Using the puller along with the heat made the job much easier. The prop will undoubtedly need to be re-hubbed, but the prop will come off if done with care and patience. The answer to preventing the prop from being stuck to the shaft in the future is to grease the prop shafts really well with Volvo Penta prop grease which works much better than anti-sieze compound per the SELOC manual. I hope this has been of some help. BZ"
