How do I adjust the idle mix screw on a 2004 mercury bigfoot 15hp?
I have drilled out and removed the factory brass plug and exposed the screw. It was set at 6 and 1/4 turns open from fully closed.
The symptoms I am trying to address are:
Some difficulty starting warm and cold. Usually have to use throttle advance to allow extra air.
Flat spot and stumble between idle and part throttle.
It is very difficult to obtain a good trolling speed. It either wants to idle or race.
It has been making oil for some time and this oil change smelled of gas.
This is a kicker motor and runs for days just above idle. It has about 14 days of run time since this springs oil change and is now about a 1/4 liter over full of oil.
I set the screw at 1.25 turns open and the idle got smooth and the flat spot dis-appeared but I would really like to use the proper procedure. I am working on muffs in my driveway and would like to have it running good before I go to the lake.
By the way my electronic service manual is silent on the matter and does not even show the adjustment screw or plug in the exploded parts diagram.
Thank You!
Thank You!
