I think I de-adjusted my sync linkage for carburetors with the Cam follower.
This is on 1970 Johnson 60 HP 3-cyl.
There's just one mark on the Cam Follower plate. Were is it supposed to be pointing when the warm up lever is on "RUN" position?
According to the manual it says that it needs to point to the center of the cam roller, but it doesn't specify if it's when warm-up lever is in "Run" or "Start" position. Which makes a difference because if lever is in "Run" (lowered) position then there is a gap of 1/16" between the Cam Follower plate and the roller itself (i.e. I cannot make the Cam Follower plate physically touch the surface of the roller). But when the lever is in "Start" position then the mark is truly pointing the center of the roller and they touch.
Can anybody give some input on this please?
The problem that I'm having is that the motor has a hard time transitioning from Idle to 1/2 Throttle, most of the time it cuts off and dies. But works 100% fine in neutral and in gear in low RPMs and also in Hi RPMs once the can be reached.
