" I HAVE A 125 FORCE O/B. NOT
" I HAVE A 125 FORCE O/B. NOT RUNNING WELL AT BOTTOM END. WILL RUN UP TO 2500 HUNDRED RPM AND STAY THERE FOR FOUR MINUTES OR SO AND THEN IT WILL KICK INTO A HIGH RPM ALL THE WAY TO 3800 RPM. I ALREADY PUT NEW PLUGS AND IT STILL DOES THE SAME. COULD IT BE SOMETHING ELSE OTHER THAN MY CARBS? I WANT TO TAKE THEM OFF (2) AND DIP THEM IN CARB CLEANER, THEN BLOW THEM OUT WITH MY AIR HOSE.IS THERE ANY THING SPECIAL I SHOULD DO BEFORE I DO SOMETHING WRONG? I WAS TOLD THE REEDS COULD BE BAD INSIDE THE ENGINE. HOW CAN I TELL IF THE REEDS ARE BAD? I DID NOT KNOW IT HAD REEDS INSIDE...(i guess they look like spark metal plug feelers)SHOULD MY 125 HP BE GETTING MORE THAN 3800 RPM? IT IS A 1986 FORCE O/B 4 CYL. 2 CARBS. BOAT SHOP WANTS $300. TO REBUILT THEM. HELP....HELP????
THANK YOU BOARD.....ED "
