1989 Evinrude E25TECEM
Already installed new water pump kit. Removed thermostat and cleaned under
the cover and closed back up w/out t'stat for salt-away cleaning.
water tube under any water pressure fills all chambers and streams out telltale hose.
Started up and only steam and exhaust smoke come out anywhere there is an outlet.
Also when running,water comes out a 3/16 hole behind the propeller hub on the port
side of foot. A factory hole. Should I start looking under the exhaust cover or the bypass
cover, or do I have a major problem?
Appreciate any help or ideas
