sean wiles
*i WANT A CONE DRIVE! THEY WERE DESIGNED IN THE 40'S BY DONALD VIVIEN HOTCHKISS AS AN ALTERNATIVE TO THE PROPELLER. tHERE ARE USUALY TWO CONE SHAPED HOUSINGS BACK TO BACK WITH A PADDLE DRIVEN *IN THE LARGE END. WITH THE CONE ON ITS SIDE ON THE FLOOR OF THE BOAT. IT IS CUT AWAY FOR ABOUT 1/3RD OF THE CONE. AS THE PADDLES SPIN, THEY DRAW WATER IN TO THE SMALL END OF THE CONE AND IT SPEEDS UP TOWARDS THE LARGE END WHERE IT IS EJECTEDAT SOME SPEED.
THESE ARE AS EFFECTIVE AS A PROP, BUT DONT PROTRUDE BELOW THE BOAT, SO VERY SHALLOW DRAUGHT. AND NO PROBLEM WITH WEEDS LOGS ETC.
SORRY THIS ISN'T A VERY GOOD DESCRIPTION BUT MAY BE ENOUGH IF YOU KNOW OF ONE.
I AM BUILDING A 16 FT ALUMINIUM BOAT USING A TELEDYNE AIRCRAFT ENGINE AND I NEED A CONE TO DRIVE IT. ANY TYPE WILL DO AS IF IT IS TO BIG OR RUSTED AWAY I CAN USE IT TO COPY AND MAKE A NEW ONE.
I WOULD APPRECIATE ANY HELP FROM ANYBODY ON THIS SUBJECT.
MY WIFE THINKS I AM SANE, EVEN IF YOU DONT!!!* THANKS IN ADVANCE. SEAN
