Eaton Beiver
So I have the infamous "Hot Restart" problem on an otherwise well-running M440. After running for a while, and getting warmed up (Ex: Pulling skiers for 30 minutes), if I shut it down for a few minutes, it fires right up. But if I shut it down for 10 or 15 minutes, it acts like its vapor-locked and flooded at the same time. It will always restart, but it take a bunch of cranking, and false starts and excessive drama. (It alarms the passengers...) I believe this is simply the "Hot Restart" problem that is somewhat common. It seems like it's heat from the engine, causing fuel to boil in the lines, possibly forcing fuel into the manifold while not running.
So my question:
Do any of you know of a solution to prevent hot-restart problems with 40 year old inboard engines?
So my question:
