OK guys, lets see if you can help me out of this jam. Please. I have a 1990 31 boston whaler, weight 13,000, powered by twin 454 crusaders with AFB carbs. It holds 325 gals. of gas,and just turned 1000 hrs. I tried to go outside with it a couple of weeks ago for Tuna, WOW ! What a suprise, We burned 23gals per hour at 3100 RPM, ON EACH ENGINE ! We traveled approx. 140 miles on all the gas we had , save 29 gals. when we got back to the fuel dock. I checked the timing, it's at 10 deg.. I checked the bottom and props , bottom ok, props just tuned before the season. Replaced the plugs , wires, distributor caps and rotors. Changed all the filters . Other than actually weighing the boat I can't actually confirm the stated weight, but I feel pretty comfortable that the hull is in good shape, had it surveyed last Sept. when I bought it and nothing out of the ordinary was found. I love this boat , but honestly , at this rate , I can't afford to drive it. I was hoping for around .9mpg and would be happy if I could get it to that. I got a hold of Chuck at crusader and he sent me the an article containing all the specs at different RPMs, that was written back in 90 when the boat came out. My boat is averaging about 1/2 of the results that they got. At WOT it pegs the floscan out at over 32 gph/per engine. I know that there is an answer somewhere, I'm just having a hell of a time finding it,and so the call for help goes out to one and all,could the answer be those 20 yr old carbs ? I think I need some more info before I spend on new carbs. Here's hoping that somebody out there has some ideas to help track this thing down.....thanks....Lee
