Window&DoorWhore
https://photos.app.goo.gl/iNz4PH46iYcqfSvE9
Attached are some photos of the rats nest under my console.
I believe most of the wire trash has to do with the radio and other abandoned wires. I’ve had the boat for several years and the gauges have never worked quite right. Original owner is a customer of mine and gave me the boat after the muskrats ate through 70% of the wires in the boat.
I replaced and heat shrinked what damaged sections I could find at the time. Boat was then stored in a slip since it all worked
worked enough
https://photos.app.goo.gl/ndVracuLHzSN2oLd8
there were a few sections like this.
I would like to replace the factory harness, replace the remote control, start over with the radio and get the pre made plug and play switch panel with the complete accessory wiring harness. I’ve seen them online and on pontoon stuff.
can anyone vouch for this remote control and wire harness set being correct for a 97 bf50?
https://photos.app.goo.gl/jiVPjzHVKbrUer728
thanks,
Patrick
worked enough
thanks,
Patrick
