Richard BD
I am having problems starting my Honda BF5, particularly after it has been run. It has a good spark, the idle and main jets and carb have been cleaned. The fuel is fresh, the filter is new, the fuel pump is pumping fuel. Compression is good. When running she idles smoothly at low revs and develops full power. Cooling water is good. Choke is OK. There is no smoke in the exhaust. She just will not start. The only way I can get her to start is by tipping a teaspoon of petrol into the cylinder via the sparkplug and then after a couple of pulls she starts up and runs as if there was no problem at all. Any ideas ? The engine has been recently acquired second hand and was totally salted up. This has all been cleaned out and new gaskets fitted. So she has probably overheated in the past. Request advice. Yours sincerely Richard BD in the UK.
