"I'M working on a honda bf
"I'M working on a honda bf 35 i beleive it's a 1997 carburated. it got really hot on the water once, came home replaced the impeller obvious problem(destroyed) put the foot back on ran excellent at high rpm pissin water. noticed it was not running right at low rpm cutting out stalling rough idle, so i pulled the carbs off cleaned them up they weren't to bad. then i put the back on the motor and out of the blue i have absolutly no spark!! i checked the kill switch nuetral safty switch, the green oil light is coming on when cranking... please help i check all wiring seems to be good any suggestions??????"
