Hi All,
I just fitted a used 2007 Honda BF30D to my boat (power tilt/electric start with genuine Honda controls). I bought the engine from a marina along way away with a 6 month warranty so I'm sure it works and it's just something stupid I've done setting it up which is why I'm posting here first rather than calling them so I'd be very grateful if anyone can help me diagnose what I'm doing wrong.
I've installed the engine on the transom. Connected up the battery cables, installed the trim gauge and the rev counter and the controls. The only thing I haven't done yet is install the gear and throttle cables as they haven't arrived yet. The engine trim works fine from the engine switch and from the controls but when I turn the key to the second position to actually crank the engine nothing happens at all. No lights on the controls(oil/overheat) and nothing at all from the engine, no noises of any kind. I've checked the connections on all the cables and they look good, and the fuses are all OK in the engine (the 4 I have found anyway). That's about all I can say, I turn the key one step and the the trim gauge jumps into life but no lights on the controls, I turn the key to start the engine and nothing at all. The selector level on the controls is in neutral and the selector on the engine is in neutral and I can spin the prop freely.
Can you confirm that the only two cables that run directly to the battery are the two thick cables that run from the engine itself? These certainly seem to work to activate the power tilt on the engine.
Does anyone have any ideas as to what the problem could be please?
Happy to post pics and any other supporting info that could be of help.
Thanks in advance............
