Honda BF2D wonbt idle
dale_genther
"I have a Honda 2hp BF2D that
"I have a Honda 2hp BF2D that we use as our dingy motor. It has always run fine, except recently it would only run with the choke knob pulled all the way out. I assumed the jets were gummed up so I took the carb. apart and removed the main jet/nozzle. I cleaned them up good and now the engine runs fine a long as the throttle is held partially open. It will not idle. On the parts dwg. I see there is also a pilot jet. I'm sure this is also gummed up. Problem is I can't find it on the carborator much less get it out to clean it. Can anyone help me in locating it and telling me how to get it out so I can clean it."
"No, It always ran great, neve
"No, It always ran great, never had to do anything to it other than routine maint. Guess I'll have to look into one. Does Honda have one, as I don't like the aftermarket manuals, such as Seloc ?"
i could send you the carb sect
i could send you the carb section if you want
yes hondad selss them for like 80 i think
email me
