Honda BF20 D not charging
jtablada
"Just got a jon boat that has
"Just got a jon boat that has a 2005 Honda 4 Stroke 20hp with a 12v/6A charger. However, I put it in the water and tested the current with a voltmeter. It is not putting out any current. I have only tested at idle. The fuse is OK. Any tips would be great, thanks."
That charging circuit does not
That charging circuit does not output a nice neat voltage like an car or an inboard's alternator. Try a small 12 volt lamp instead and rev it up slightly.
"have tried it at higher RPM&#
"have tried it at higher RPM's still no current at all. tried changing the fuse just in case, no difference."
"Check the rectifier. If you
"Check the rectifier. If you have voltage going in, but not out, that could be it. Otherwise, might be the alternator coils."
The voltage into the regulator
The voltage into the regulator is AC... either use a meter on the AC scale or a light bulb as previously recommended.
you need a load on the chargin
you need a load on the charging system for it to work
you will get no reading on it without a load
